Car sat idle for over 2 years. Car started twice just prior to repair work. Replaced timing belt, water pump, fuel and air filters and put fresh gas in tank. Can hear fuel pump running when ignition turned on. Had fuel flow when fuel filter changed. Ignition has good spark and timing seems close when checked statically. Inertia switch checked, reset and plug removed and reinstalled to confirm good connection. Battery good. Fuel cutoff light stays on and engine will not start.
Oct 23, 2008 at 2:55 PM
