WAS RUNNING ROUGH AND IDLE WAS ERRATIC FOR ALONG WHILE . STARTER NOW CRANKING BUT NOT STAYING ENGAGED ALL OF THE TIME . PROBABLY DAMAGED FROM LONG CRANKING TO GET CAR STARTED . CAR WILL NOT START EVEN WHEN CRANKING . CHECKED ENGINE CODES TWO CODES CAME UP . OXYGEN SENSOR AND EGR SENSOR SOLENOID . CODES 17 AND 28 . HOW DO I REPAIR THESE CODES AND WILL FIXING ONE CODE AFFECT THE OTHER . DOES STARTER PROBLEM AFFECT THE CODES
Aug 14, 2008 at 11:11 AM
