What would cause the parking lights, instrument cluster an taillights to stop working. To start the orange wire in the fuse box under the hood burned out. I replaced an rewired the entire relay all the way back to the fuse box in the car ( driverside just left of the clutch pedal). There is now power coming into relay via the main fuse connection under the hood. I also have power leaving the relay via the green wire controling the headlights ( witch work now).
updated 10/26/09
no that did not answer the question. the green wire has power all the way back to the dashboard. if i by-pass the relay an touch the orange wire to the battery everything comes on. would it be stupid to just put in switch an fuse to bye-pass the relay.
updated 10/26/09
Oct 25, 2009 at 11:32 AM
