Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Probe
Electrical
Alternator
Voltage Regulator
1991 Ford Probe Voltage regulator
1991 FORD PROBE
15,400 MILES • 6 CYL • 2WD • MANUAL
PROBE EMANUEL
MEMBER
1 POST
FOLLOW
Will the Voltage regulator cause the head/taillights to stop working? Should I Change the fuse or the bulbs, when i change the regulator?
May 17, 2008 at 12:01 AM
CERTIFIED EXPERT
I don't think so-the lights will come without the voltage regulator-The voltage regulator's job is to maintain the alternator output.
I recommend you load test the battery and alternator to ensure both are in working condition. Then start checking the headlight switch.
Also check the fuse no.5 15amp fuse tail that's okay were right back to the headlight switch
May 17, 2008 at 12:17 AM
