1991 Ford Probe low oil light came on while driving but gau
1991 FORD PROBE
190,341 MILES • 6 CYL • FWD • AUTOMATIC
MSMUPET1
My low oil light came on while driving and is staying on, but when I checked the oil it was only 1/2 quart low. I added the 1/2 quart of oil but the light remains on. The oil gauge shows normal oil pressure but the battery gauge shows a high reading of almost 17. (Normally this reads within the normal range.) Is this an electrical problem or a mechanical problem and what is the cause?
Jun 21, 2010 at 6:11 PM
The alternator is overcharging the battery -battery could explode get it checked out-it should be in this range 13-15volts
Oil light on:
Check the oil pressure with a mechanical gauge if normal replace the oil pressure switch abnormal could mean oil pump and engine bearings.
Jun 21, 2010 at 7:34 PM
