i stuck a screwdriver in my ignition (my father took my keys) and i figured blah it will work but i'm not sure if i messed the ignition switch up cause i still don't have the keys
and i used a paper clip to try to move the pins up but i don't know if there messed up because i just figured that when you stick the key in it moves the pins up and when you push it up it just falls back down (i didn't think of that till after i did the thing with the paper clip)
but if you could tell me if that would mess up the ignition switch or not that would be great
Aug 19, 2008 at 6:27 PM
