1990 Ford Probe won't run
1990 FORD PROBE
RDBUG
  • 4 POSTS
Electrical problem
1990 Ford Probe 4 cyl Front Wheel Drive Automatic
it won't run, replaced distribitor & coil . All fuses & relays test good, getting gas just no spark. where do I go from here ?
Aug 11, 2008 at 8:35 PM
Check the Thick Film ignition control module
Aug 11, 2008 at 8:42 PM
RDBUG
  • 4 POSTS
if you are talking about the one in the distributor , I replaced it along with the stator .
Aug 12, 2008 at 3:24 PM
Do below to check for spark
https://www.2carpros.com/forum/automotive_pictures/12900_ds1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_ds2_1.jpg
Aug 12, 2008 at 4:51 PM
RDBUG
  • 4 POSTS
no affence, but it does not have a dura spark II ignition system. I am familier with those. This has the ignition modual in the distributor on top of the stator . There is power to the coil when cranking & with the key on . I have tested the new coil & Distributor in another car even though they are new, and that car ran fine. The old one's tested bad by means of an ohms test , so that's why I replaced them.
Aug 13, 2008 at 8:55 PM
Last stop is the crankshaft positioning sensor located below
https://www.2carpros.com/forum/automotive_pictures/12900_cps1_4.jpg
Aug 13, 2008 at 9:02 PM
