Relays seem to be funtioning, clicking on when ignition is activated. Installed new coil. Still no spark. Removed ignition module and had tested. Tested good. Connections are clean and no change in engine cranking speed. I was told that I could have a bad distributer. Are there any test that can confirm that or is there something else I'm missing? I was also told about a fuel shut off safty switch in the back of the car that can go bad or that would cut off power when in an accident. This car was never in an accident. This car does sit alot and not garage kept.
Dec 30, 2009 at 11:06 AM
