1989 Ford Probe no spark
1989 FORD PROBE
185,000 MILES • 4 CYL • FWD • MANUAL
ANTHONYJALCALA
  • 5 POSTS
Relays seem to be funtioning, clicking on when ignition is activated. Installed new coil. Still no spark. Removed ignition module and had tested. Tested good. Connections are clean and no change in engine cranking speed. I was told that I could have a bad distributer. Are there any test that can confirm that or is there something else I'm missing? I was also told about a fuel shut off safty switch in the back of the car that can go bad or that would cut off power when in an accident. This car was never in an accident. This car does sit alot and not garage kept.
Dec 30, 2009 at 11:06 AM
DOCFIXIT
  • 18,828 POSTS
Hi
With test light key on see if voltage on coil + white/red wire. if good place light on coil neg. crank does it flash?
You had TFI checked?
Let me know
THanks for donate
Dec 30, 2009 at 12:13 PM
ANTHONYJALCALA
  • 5 POSTS
I do not know what the TFI is and how to check it. I still have to perform those test on the coil and I'll let you know the results. Cold in Wisconsin today!
Dec 30, 2009 at 2:06 PM
DOCFIXIT
  • 18,828 POSTS
TFI mounted to side of Dist.
Dec 30, 2009 at 2:17 PM
ANTHONYJALCALA
  • 5 POSTS
The TFI is mounted to the distributer on V-6 models. I have a 4cyl. turbo.The ignition module on my car was tested and is mounted on a bracket on the side of the coil. It tested good. Can there be a intermittent problem with a module that test good or can there be a problem with the test procedure at the parts store that I had it tested at? Voltage to coil+ White/red wire, Good. Coil neg. light remains on when cranking engine.
Dec 30, 2009 at 4:43 PM
ANTHONYJALCALA
  • 5 POSTS
Out of office over the holidays?
Still stalled. Any other recomendations ???????????
Jan 4, 2010 at 12:37 PM
DOCFIXIT
  • 18,828 POSTS
Pull dist. cap crank engine rotor turn?
Jan 4, 2010 at 4:12 PM
ANTHONYJALCALA
  • 5 POSTS
Checked distributer, okay. Reassembled and car started. Ran good for about an hour and then engine began to clatter and quit. Cam gear was loose and aligning hole was oblonged.Not sure why. Timing belt may have jumped. Could be serious!
Anyway, Thanks for the help with my origional problem.
I may have to come back with new question down the road.
Jan 8, 2010 at 7:37 PM
DOCFIXIT
  • 18,828 POSTS
Good luck engine interference ie. valve bender
Jan 9, 2010 at 1:42 PM
