1989 Ford Probe main fuse is blown
1989 FORD PROBE
280,000 MILES • 4 CYL • 2WD • MANUAL
CTQWORKS
car was driving fine. lights were dim (all). Car died at a stop sign. Popped the clutch to get it going again.... it died. Main fuse was blown but may have happened while trying to jump it. First how do I get that fuse out? What would make the battery die to the point that it won't start? Altenator? or Battery? or both?
Jan 12, 2008 at 9:18 PM
BMRFIXIT
  • 19,053 POSTS
[quote:ed52909304="ctqworks"]Electrical problem
1989 Ford Probe 4 cyl Two Wheel Drive Manual 280000 miles
car was driving fine. lights were dim (all). Car died at a stop sign. Popped the clutch to get it going again.... it died. Main fuse was blown but may have happened while trying to jump it. First how do I get that fuse out? What would make the battery die to the point that it won't start? Altenator? or Battery? or both?[/quote:ed52909304]
its the charging system (alternator) you must crossed the jumper cables when you tried to jump it that is a reason why fuse blown
Jan 12, 2008 at 9:24 PM
You must unbolt the fuse panel and use a 8mm wrench to remove the fuse in question.
Dec 30, 2024 at 12:54 PM
