I have a 1989 Probe GT mileage is 175K +. I am having a problem with the fuel system. I test drove the car on Jan 3rd. Everything worked fine excep the heater never came on. I purchased the car and drove it home. It drove exceptional. Excpet that the car began to overheat. I replaced the valve cover gasket because it was cracked and the thermostat (iw was froze shut). Then the car would not run. It cranks fine but does not run. I replaced the fuel pump because I could not hear it turn on. It still will not run. I am told that it may oe be the fuel relay switch. I have no idea where this is located on my car can you please help.
Jan 12, 2010 at 3:22 PM
