Engine Mechanical problem
1988 Ford Pinto Two Wheel Drive Manual
HELLO GUYS,hope you can help have a pinto engine and it runs great blows oil around dipstick and carb,not a lot i am concerned about this no smokeing good performance,thinking of changing oil breather housing on block,did hear it could be rings,should i do compression test,plugs are great,the engine is in a kit car and has only done 6k mile since being overhauled,would it show on compression test as it would be the oil srcapper rings also what should the compression test value be
thank you very much
regards
michael
thank you very much
regards
michael
Aug 25, 2010 at 11:47 AM
