Engine Performance problem
1978 Ford Pinto 4 cyl Two Wheel Drive Automatic ???? miles
I have replaced my camshaft,the timjng pointer is obviously bent, when i run the engine, tie timing indicator on the cranshft shows very late (maybe15-20deg.late i;m sure the cam needs moing at least 1tooth but which way? WhenI move the dist. to try to correct it the engine will just rough up and try to quit. facing the front of the engine clkwise or counter clockwise?
Sep 25, 2010 at 8:13 PM
