Usually the inertia switch is located on the right rear quarter panel behind an access panel or small door, depending on car,, sometimes you must remove a trunk trim panel to access it,, it's usually near the side marker light, or in front of the tailights.. push the button on top to reset, why would you need to do this, did you hit or be hit hard enough to trip this switch???
Apr 15, 2007 at 6:39 PM
