Hello, I am driving a 1996 Ford Powerstroke Turbo Diesel. As I was coming to park today the power steering suddenly went dead. I finished parking and opened the hood. It appears that the high pressure output line popped right out of the pressure fitting at the base of the pump/resivoir. The male and female parts of the fittings look undamaged.
Here is my question, I believe that all I need to do is loosen the first nut on the fitting and slip the hose fitting back in and tighten it down. I just don't know which way to turn the nut because it looks like one of those dual combinations that could require twisting in the opposite direction to loosen. I dont want to damage it further because it isn't mine and that puppy is tight.
Edit> Ive done some additional research and it is begining to appear that this is a larger problem than I suspected. The fitting should all be one piece on the hose side. Any input is greatly appreciated.
Any help or opinion would be great!
Thanks Zoo
Thanks Zoo
Mar 19, 2007 at 1:52 PM
