I'm thinking a vacuum\pressure tester is used, in conjunction with a voltmeter, not quite sure what the order or series of tests consist of..
Dec 30, 2006 at 2:40 PM
TAURUSWHEEL
CERTIFIED EXPERT
ABADAY
MEMBER
use a vacuum gauge and hook it up to intake vacuum the reading should be steady around 17 to 20 in then hold the rpm up to around 2500-3000 and hold it there for about three minutes if the gauge drops to low vacuum and dosent recover you have a restriction
