Ford Falcon Futura 93" 4.0ltr increasing idle
1993 FORD
BPCR
I have a ford falcon futura ED, it has done 300,000ks the motor was reconditioned at 280,000, i had a problem where my car wouldn't idle, you would have to rev it when you started it to keep it running, i was told it was the idle air controll so it was replaced for a new one AU$265 since then my cruise controll no longer works, the idle speed is higher and the revs go from 1000 to 1500 at idle and when driving when you put the clutch in at 2,500 the revs stay at 2,500 and after about 15 seconds they begin to slowly come down again. it is also using alot of fuel. any help would be great. Donation Made.Receipt ID: 38P97600A7949544G
Nov 10, 2007 at 10:13 PM
SERVICE WRITER
  • 9,123 POSTS
I seriously doubt it..but you never know.
Aug 28, 2007 at 7:55 PM
BMASTERJERRY
  • 47 POSTS
[quote:6babcab849="jwyatt44"]I HAVE A 1998 FORD TAURUS, 6 CYL, 3.0 ENGINE.
SOMEONE PUT SOMETHING IN MY GAS LINE MALICIOUSLY AND I AM TRYING TO GET THE INSURANCE COMPANY TO PAY FOR SOME OF THE COSTS. WILL THIS CAUSE THE CATALYTIC CONVERTOR TO BE DIAGNOSED AS BAD AND COULD IT STOP IT UP[/quote:6babcab849]
What was it?
Aug 29, 2007 at 8:16 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You should get a fault code read. to be sure there is no problem in engine management system. The MAP sensor on the fire wall behind the inlet manifold can cause this problem as can a vacuum leak, often from the plastic out let at the bottom of the inlet manifold. It would not be the first time a new idle control motor was faulty either.
Mark (mhpautos)
Nov 11, 2007 at 3:47 AM
SERVICE WRITER
  • 9,123 POSTS
I agree with Mark, need to get the codes pulled for a start. I'm not familiar with the model you have as it is non-US, is it a sister car to one of the American models?
If a shop replaced the IAC, and the cruise stopped working, I would ask them to recheck their work.
Like Mark said, check for a vacuum leak, disconnected or cracked hose maybe, air intake not tight or leaking.
Nov 11, 2007 at 5:52 AM
