I have a 1994 cougar xr7, v6, auto, with 178,000 on chassis, around 45,000 on motor. I bought it used 2 mo. ago. The check engine light came on and the codes were 116, and 332. Since then I cleaned the egr valve, since I could not get the valve off the pipe, replaced the egr valve sensor and the egr vacuum solenoid. The egr valve works when I put vacuum to it. The problem is the light still comes on. The light does not come on until I move the throttle.
Thanks
Thanks
Feb 24, 2006 at 9:20 PM
