dpfe sensor
FORD
LORI HEBERT
I have Mercury sable my check engine light is on the code that comes up is the EGR Valve is malfunctioning. I got a resopnse that fords and known for the dpfe sensor going bad. Where is it located? What should I use to clean it? Thanks for you help :wink:
Apr 8, 2006 at 7:57 AM
PEPPERMRJ
  • 1,158 POSTS
Can't realy clean it. You can clean the EGR and it's port with carb cleaner and an old tooth brush. If that does not work check or have the DPFE sensor checked and replaced if necessary.
Good luck and let us know. :)
Apr 8, 2006 at 10:11 PM
