checking rear brakes
FORD
POPLAKIN
2001 - fiesta - endura E engine - 1293. - 2 door. I would like to check the rear brakes. according to the Haynes manuel the best way is to undo the centre nut and pull the complete drum and bearing off. There is a "cage" around the nut, do I just undo this with the nut,and do I need to buy a new cage to refit? Thank you Pop.
May 6, 2007 at 3:21 PM
MERLIN2021
  • 17,250 POSTS
If there is a cotter pin remove the pin if not remove the nut cage and all.
May 7, 2007 at 2:36 PM
