check engine light still on after changing all O2 sensors
FORD
DABO1997
I had all the Oxygen sensors changed but the check engine light is still on. What else could it be?
Mar 4, 2007 at 1:24 PM
TAURUSWHEEL
  • 718 POSTS
You didn't mention what car??? Why did you change all the o2 sensors??? I've never heard of all failing at once, unless you only have one,, what codes did you get??? The check light won't necessarily turn off for a certain number of warm-up cycles where no further faults are noted,, you can have the light turned off though the car will have to run through alll it's self-checks again, that's why you can't turn a light off for emission checks if required, it'll show up.
Mar 4, 2007 at 3:21 PM
DABO1997
I have a 2002 Ford Windstar. I changed all the sensors cuz a mechanic told me it's both Bank 1 and Bank 2 too lean.
Do you think it might be a leak in the intake manifold?
Mar 4, 2007 at 4:26 PM
EESHABR
  • 4 POSTS
dabo1997
Mar 12, 2007 at 10:10 AM
JACOBFEGLEY
  • 8 POSTS
ive seen alot of those with vacuum leaks
Mar 21, 2007 at 12:01 AM
