Car Overheating only while brakes are applied or air is on
FORD
RHORNE
I have a Mercury Sable 1999, v-6, with 94,000 miles. My car overheats only when the brakes are applied and sitting idle or when the air conditioner is on for awhile; however, if I put the car in park it will not run hot. I have had a new water pump put on, thermostat replaced, hoses checked going to radiator for leaks, new reservoir, and the fans are coming on. I do not believe it is the heads because then it would be running hot at all times. Please help before I have to spend a fortune on my car. It has been checked out by Firestone who could not diagnose the problem.
May 22, 2006 at 12:54 PM
LARRYHE
  • 8 POSTS
The fans are on all the time? Even when it is over heating?
May 24, 2006 at 12:45 PM
RHORNE
[quote:632abe0e34="larryhe"]The fans are on all the time? Even when it is over heating?[/quote:632abe0e34]
They seem to be running whenever I check; however, I haven't looked every time it runs hot.
R. Horne
May 24, 2006 at 2:56 PM
