to replace the brake switch in a towncar you have to remove the plastic covering under the dash that covers the switch there should be three plastic push in plugs that you have to pry out and the cover will come off and you will be able to see the brake switch above the petal. remove thye wireing clip. then a pin holds the switch in pos. rev. the process to install
May 27, 2006 at 2:27 PM
