Average life of catalytic converter?
FORD
BESTBET777
  • 89 POSTS
How long does the average catalytic converter last before it blows a head gasket or some other surprise?
Apr 30, 2007 at 1:42 AM
There are two ways a converter can fail:
It can become clogged.
It can become poisoned.
There really is no "inspection port" for the consumer or mechanic to see an actual clog in a converter. Often, the only way to tell if a catalytic converter is malfunctioning (plugged) is to remove it and check the change in engine performance. When a clogged converter is suspected, some mechanics temporarily remove the O2 sensor from the exhaust pipe ahead of the catalytic converter and look for a change in performance.
A catalytic converter relies on receiving the proper mix of exhaust gases at the proper temperature. Any additives or malfunctions that cause the mixture or the temperature of the exhaust gases to change reduce the effectiveness and life of the catalytic converter. Leaded gasoline and the over-use of certain fuel additives can shorten the life of a catalytic converter.
A catalytic converter can also fail because of:
Bad exhaust valves on the engine
Fouled plugs causing unburned fuel to overheat the converter
Sometimes you can tell that a converter is clogged because you don't go any faster when you push the gas pedal. Also, there usually is a noticeable drop in gas mileage associated with a clogged catalytic converter. A partially clogged converter often acts like an engine governor, limiting the actual RPMs to a fast idle. A totally clogged converter causes the engine to quit after a few minutes
Typically has a warranty length that exceeds the term of the warranty for the rest of a typical U.S. automobile because of all the increased exhaust back pressure
They will usually go over 100K miles as long as the engine hasn't caused damage due to its own issues. Some vehicles had problems with the cats , while others never seem to go away.... They are made of reactive material, so they are degrading from the first moment they are used
Apr 30, 2007 at 3:16 AM
TAURUSWHEEL
  • 718 POSTS
I think most of the emission parts are 8 yrs, 80k miles under federal rules..
Apr 30, 2007 at 5:13 PM
