93 ford t-bird misfire and rough idle
1993 FORD
BAGGEDBIRD93
  • 4 POSTS
Hopefully someone can help. I have a 93 t-bird v6 3.8ltr. I put a new engine and transmission in it. I drives and runs great, seems to lack a little power though. At idle it sputters and eventually dies. I set the idle at 550rpm and the timing at 10 deg. BTC. I sit and watch with a timing light and for about 20 seconds the timing is good, then out of no where it jumps aroud and sputters, the timing goes from 20 BTC to 10 ATC back and forth then dies. If i rev it up to 800+ rpm then the timing goes strait to 10 btc and doesnt move. I put all new sensors, air idle control valve, throttle position sensor, cap and rotor, plugs and wires, even fuel pressure regulator. I am stumped and have dumped a few thousand into the car now. Please help. A friend tells me that since the engine is bigger now that the computer will need to be reprogrammed to compensate the new fuel air mix. But I thought O2 sensors did this? Please any advise to avoid taking it to ford. Thank you
Jan 25, 2006 at 8:24 PM
LOVESCARS
  • 359 POSTS
It's likely the computer trying to compensate for the difference. Call a salvage yard to see if the computers are they same. be sure to have you computer number available to match up.
Jan 25, 2006 at 9:41 PM
BAGGEDBIRD93
  • 4 POSTS
But it is the same engine, just rebuilt.
Jan 25, 2006 at 9:57 PM
LOVESCARS
  • 359 POSTS
You had said new engine. Could be the distributor or timing gears sounds like you've already replaced everything. This a turbo?
Jan 26, 2006 at 7:06 AM
BAGGEDBIRD93
  • 4 POSTS
nope, not a turbo.
Jan 26, 2006 at 10:10 PM
GODBEAR839
  • 77 POSTS
Was it the same engine (same type of car, same year, same everything) or was it a similar engine from another type of vehicle.(like a 3.8 from a van or truck)Also did you check the timing on it before you put it in? Made sure the timing belt/chain was where it was suppossed to be?
Jan 27, 2006 at 7:31 AM
BAGGEDBIRD93
  • 4 POSTS
The timing is correct. It is the same engine, but completly rebuilt.
Jan 27, 2006 at 6:03 PM
