92 Ford TBird 3.0L engine head gaskets
1992 FORD
MOCHINSKIR
At 115,000 miles a head gasket blew on my 92 Tbird and I had the friendly and costly Ford dealer do the repair work. I found that this engine is prone to this problem because the block is a different metal than the heads, which are possibly aluminum. Now 2 years later and at 120,000, I am experiencing similar problems, and the friendly Ford dealer is telling me I need to replace the head gaskets again. I know that engine heat can cause the heads to warp and this can contribute to the gasket problems. I haven't done anything special to the engine, usually run regular gas, a couple of times a year I may use a higher octane premium fuel. What else can I do to reduce the risk of head gasket problems due to excessive heat? Should I use a cooler thermostat? Or just not use the engine?
Mar 25, 2007 at 10:01 PM
MERLIN2021
  • 17,250 POSTS
First off if you do replace head gaskets...get both done at the same time, have the heads planed flat, and in a perfect world...use Fel Pro gaskets!
Mar 26, 2007 at 5:20 PM
TAURUSWHEEL
  • 718 POSTS
The gaskets lasted only 5k miles??? Sounds like a bad replacement job, the 3.0 engine is a hardy engine not prone to headgasket failure, unlike the notorious 3.8... engines today are seriously affected by overheating them, not regular heating and cooling,, do not run a cooler thermostat, it will screw up your engine control system, the engine must run at or near the specified temps for best perfomance
Mar 27, 2007 at 10:56 PM
