2004 Other Ford Models Replace rear light bulb
2004 FORD
45,000 MILES • 4 CYL • 2WD • MANUAL
SIMCE
Can you please help me with information how to safely open rear plastic that covers brake lights that i need to replace?
Thank you,
Sime
Dec 25, 2007 at 6:09 AM
SERVICE WRITER
  • 9,123 POSTS
Not knowing what model might help, but posting a pic of where you mean would be better. Center brake light? side brake lights?
There are some that are retained by a series of nuts, others that push pin. The push pin style has a small center section that pulls out and then the whole fastener can be pulled out.
Dec 25, 2007 at 7:28 AM
SIMCE
Hi, Thanx for the replay. The model is MK6 and i need to remove rear right light cover (circuled on the picture). After you replied i found one wing screw on bottom from inside of the plastic and one bolt on top. But i do not know how to remove top bolt screw (i'm affraid to pull the plastic harder to not brake it). Is there any tip how to remove top bolt? BR, Simce
https://www.2carpros.com/forum/automotive_pictures/134403_ford_fiesta_mk6_ST_rear_red_car_1.jpg
Dec 26, 2007 at 5:45 AM
SERVICE WRITER
  • 9,123 POSTS
show me a pic of the one you can't get out,
I am not familiar with that model.
Dec 26, 2007 at 9:25 AM
