2004 Other Ford Models 6.0 diesil
2004 FORD
KSANDERS
Other Category problem
2004 Other Ford Models Four Wheel Drive Automatic 100000 miles
Where is the cold weather "plug up" for a 6.0 ford power stroke diesel located on the engine block?
Dec 17, 2007 at 9:54 AM
DR LOOT
  • 2,311 POSTS
the Glow pugs on a Power stroke are located under the valve cover and cost about $90.00ea. your own board computer can check which one is are burned out, if you have access to a scanner, maybe AutoZone or Checker will run the check for you
Jan 26, 2009 at 8:54 PM
