2003 Other Ford Models Engine Management Light
2003 FORD
TRUDIM
Engine Mechanical problem
2003 Other Ford Models Manual
Hi, I have a Ford KA the engine management light is on. The car itself runs fine, never had any problems with it, even now when the light is on. Although when the car is stationary and the clutch is put down there is a a knocking sound, once it is gear the noise goes and the same when it is in neutral. I know i need to have a diagnostics test done, but was just wondering if you have any sort of idea what could be causing this.
Thanks
Trudi
May 8, 2009 at 5:51 AM
MMPRINCE4000
  • 8,548 POSTS
Get the car scanned, but if knocking dissappears when clutch is depressed, it is either throw-out bearing, or loose flywheel bolts, possible diaphram finger(s) bent.
In any case you will most likely have to drop trans and replace clutch.
May 8, 2009 at 6:24 AM
