2002 Other Ford Models misfire, bucking ,jerking under load
2002 FORD
147,000 MILES • 6 CYL • FWD • AUTOMATIC
HOTROD65
hi, I have a 02 ford windstar and we drove through some standing water and the car started cutting- out and back-fired a couple of times. then it settled down and ran ok. later, we noticed when we were goining up hill or the passing gear kicked in, the engine would cut -out or miss intermittently causing the car to buck and jerk. To my suprise,It has set no codes. I have been expecting a misfire dtc, but nothing. I am thinking maybe the coil pack is cracked or the crank sensor was damaged. I inspected the tone wheel on the harmonic balancer, all the teeth were straight and none were missing. any advice would be greatly apprecieted.
thanks john
Jun 11, 2010 at 7:09 PM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Jun 11, 2010 at 7:14 PM
