2001 ford zx2--99802
2001 FORD
HITMAN2
:? my car mil light came on. coed was p0340,p1383.cam pos, and variable cam over retard (bank 1 ) ford.
timeing belt was shot also replaced timeing belt and p0340, cleared codes, new codes came up,and still running rough, p0340, p0300, it said misfire cyl-1, then p0300. multiple/ random ,multiple cylinder misfire detected. replaced vcm seloniod and checked vc timeing and timeing belt setting, all were aligned but still getteing these codes, and help or suggestions wuold be very helpful. thank u james.
Mar 19, 2006 at 7:11 PM
PEPPERMRJ
  • 1,158 POSTS
Start with clearing the codes.
Check for vacuum leaks. Don't forget around the intake manifold.
Faulty spark plugs or wires
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector(s)
Burned exhaust valve
Faulty catalytic converter(s)
Stuck/blocked EGR valve / passages
Faulty camshaft position sensor
Defective computer
Good hunting. :)
Mar 20, 2006 at 6:24 PM
HITMAN2
i'll try that thank you.
Mar 20, 2006 at 6:49 PM
