1997 Other Ford Model s window trouble
1997 FORD
GHUGHES
Electrical problem
1997 Other Ford Model s V6 Front Wheel Drive Manual 59000 miles
hello. the paasenger side window wont open with the driver side switch,although it opens with its own switch,also the switch on the driver side light flickers when the carlights are switched on.
i hope i have described this problem to the best of your knowledge--thanks
Dec 6, 2007 at 11:56 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
As the window will go up and down with it's own switch, the circuit and motor are fine. I would suggest that the switch pack on the drivers door is faulty, it can be tested to prove the fault, but most switch packs are not made to be repaired so a new switch assembly may be required.
Mark (mhpautos) :D
Dec 6, 2007 at 7:13 PM
