Hi there,
Some transmissions have a drain plug, others have to have the pan removed, If you remove the pan, replace the pan gasket and filter element, re fill with approved oil for your transmission and check the level is correct when hot as per your cars instructions, check for leaks., when finished.
Mark (mhpautos)
Jan 6, 2008 at 4:08 AM
