1994 Other Ford Models Tachometer REV Counter
1994 FORD
168,000 MILES • 6 CYL • 2WD • AUTOMATIC
WESLEY1234
Hello there,
I have a 1994 Ford Granada 2.9i Ghia V6 which is automatic.
The problem is with the Rev "tachometer" counter in regards to the needle moving anti-clockwise and starts at 7000rpm's and goes up to 3000rpm's. Sometimes if you "rev" the engine hard, the needle goes back to normal then will act crazy moments later.
Does this mean that I need to purchase a new tachometer or could it be an electrical problem as someone has suggested it could be the +/- contacts on the ignition coil?
Any help would be gratfully apreciated.
Regards
Wesley D. Jordan
Jun 28, 2008 at 12:34 PM
KHLOW2008
  • 41,814 POSTS
Hi Wesley1234,
My guess is the tachometer is faulty. The circuit board might have some bad connections, if you can take it out and resolder all the points, it might solve the problem.
Check the meter ground as well.
Jun 29, 2008 at 5:03 AM
