1983 Other Ford Models No Fire out of Coil
1983 FORD
DELY6875
Electrical problem
1983 Other Ford Models 6 cyl Two Wheel Drive Automatic
It is a Ford Ecnoline Van, It turns over but will not start I checked the coil & it has no fire out of the coil wire. Any ideas?
Jul 21, 2009 at 11:08 AM
HMAC300
  • 48,601 POSTS
get an ohm meter and check the pickup coil in the distributor. you'll have to check it for resistance. If it has over 800 ohms then you'll need another one.
Nov 11, 2009 at 7:48 PM
HIPPO800
  • 29 POSTS
Don't buy or use a ballast type coil.
They take too long to build up charge.
Use an MSD Blaster SS coil with stock control unit.
The Ford horseshoe connector is stupid and brass screw terminals conduct current better.
Use stainless lockwashers though with good ring terminals.
That is, if the coil is proven faulty via, ohm meter.
Put the stock coil in the fridge and check the resistance as well.
The MSD unit is unaffected by cold.
Feb 3, 2010 at 8:13 PM
