1978 Other Ford Models Stalling, sputtering at higher speeds
1978 FORD
DHANEY1974
Engine Performance problem
1978 Other Ford Models V8 Two Wheel Drive Automatic unknow miles
My truck stalls or hesitates, sputters, sometimes backfires at around 40 to 50 mph. I can let off the gas and usually it will idle down and I can accelerate again. I've checked the plug wires, plugs, distributor, coil and could not find a fuel filter anywhere from carb inlet to gas tanks, so I installed an inline filter. I have 2 gas tanks and sometimes can switch from the auxilary tank to the main and it seems to act better for a moment, but then the same problem. An 'import' mechanic said I have carb problems while another said I should check to see if the tanks have filter screens in them where the fuel line go's in. Sometimes it even does this at lower speeds. Any suggestions on what I should do? It has an edlebrock 4 barred carb.
Apr 1, 2009 at 12:46 PM
MIKE H R
  • 3,094 POSTS
the fuel filter should screw into the carburator. With it ruinning all right a slower speeds then I would change the fuel filter on the carb.
Apr 17, 2009 at 10:27 AM
