1964 Other Ford Models Question on Clutch - 1964 F100
1964 FORD
63,000 MILES • V8 • 2WD • MANUAL
JWD396
1964 Ford F100 Pickup: Had the clutch worked on by Ford dealership 3 years ago. They replaced clutch pressure plate, throwout bearings, and resurfaced the flywheel. I do not drive this truck very much. Since it was worked on, it does not operate as smooth as I think it should.
And here is a noise that comes and goes at 50 to 60 MPH. It is a vibration, not quite high pitched noise. And it quits when I tap the clutch pedal. It has not been making the noise lately. Just put $6000 in body wrk/paint. Would like for it to run smooth. Any thoughts on what it could be? Thanks.
JWD
Apr 7, 2008 at 6:45 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
If the noise goes when you just touch the clutch, i would be thinking a sticky thrust bearing. I would be checking it first.
Mark (mhpautos)
Apr 8, 2008 at 4:19 AM
