aod transmission and 302 thermostat housing
1930 FORD MUSTANG
EVERETT HOBBS
i have an AOD transmission and 302 engine out of a 1985 t-bird i put in a 66 mustang. cant get tranny lines to come out of fittings going in to case. they leak very bad. i have new fittings with plastic insides but need to know if there is a tool or trick to seperating. also having bad luck with thermostat housing on manifold. have tried gaskets 2 times and different silicones with no luck. i must be overlooking something. can you please help
May 10, 2007 at 5:21 PM
2CARPRO JACK
  • 11,533 POSTS
Yes, I believe there is a special release tool. Local auto parts house might have them. I use general trim adhesive to hold the gasket in place, silicone can cause the gasket to squirt out when tightened
May 10, 2007 at 6:15 PM
