2010 Ford Mustang Spark Plugs
2010 FORD MUSTANG
13,500 MILES • 6 CYL • 2WD • AUTOMATIC
ZIPPOC04
At 13500 I replaced my spark plugs as preventative maintenance as well as ton keep the plugs from seizing. Is there any harm in not using Motocraft plugs. I realize the engine may run best on OEM plugs, but is there any harm in using the NKG Iridium IX plugs that I just installed. My justification in not using stock plugs is the longevity of the iridium. I have no preference of the brand, I just know NKG is a good brand for plugs. The new installed plugs are the correct heat range and have been gapped to the car's specifications. Thanks!
Jul 23, 2010 at 10:47 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
The Iridium plugs are a perfect match for your engine, but you should not adjust the gap on iridium plugs, they are pre set and should not be touched.
mark (mhpautos)
Jul 24, 2010 at 6:21 AM
ZIPPOC04
Thank you for the answer. The plugs were gapped at .03" when I got them (maybe messed up during shipping) so I widened them to the car's specifications of .052"-.056. Thanks again for the help.
Jul 24, 2010 at 8:07 AM
