2006 Ford Mustang noise at start up
2006 FORD MUSTANG
BVALEN74
Noises problem
2006 Ford Mustang V8 Two Wheel Drive Manual
I have a squealing noise coming from clutch/transmission when I first start my car. After the car warms up, the noise goes away. It's a 5 speed manual transmission and I was wondering if my clutch needs to be replaced or is there an adjustment I need to make?
Nov 21, 2009 at 6:17 PM
DOCFIXIT
  • 18,828 POSTS
Hi Maybe throw out bearing does it stop squealing when clutch disengaged? or could be input shaft bearing is trans fluid level up?
Let me know
Thanks for donate
Nov 23, 2009 at 10:11 AM
BVALEN74
Thanks for the reply docfixit. It does go away when clutch is disengaged. I was also thinking maybe throw out bearing, but wasn't sure. Tranny fluid is up, so I'll start with the throw out bearing. Thanks again.
Nov 25, 2009 at 5:20 PM
DOCFIXIT
  • 18,828 POSTS
Your welcome if can afford replace clutch assembly with Center Force you will be pleased. The hook up and improved shifting is remarkable.
Nov 30, 2009 at 12:05 PM
