2005 Ford Mustang Engine is overheating when in bumper to b
2005 FORD MUSTANG
40,000 MILES • 6 CYL • 2WD • AUTOMATIC
DARYLF_1
I have purchased a replacement thermostat but want to know how to install it.
Jul 6, 2010 at 8:06 AM
BLUELIGHTNIN6
  • 16,542 POSTS
4.0L Engine
Drain the cooling system.
Remove the air cleaner outlet pipe.
Remove the throttle body.
Remove the 3 upper thermostat housing bolts and position aside the thermostat housing. Discard the thermostat O-ring seal.
Remove the thermostat.
To install:
Installation is the reverse the removal procedure. Please note the following:
A.Install a new thermostat O-ring seal and lubricate with clean engine coolant.
B.Tighten the 2 upper thermostat housing bolts to 89 inch lbs. (10 Nm)
Fill and bleed the cooling system.
Jul 6, 2010 at 10:42 AM
