2004 Ford Mustang Clutch release lever
2004 FORD MUSTANG
89,000 MILES • 6 CYL • 2WD • MANUAL
PAULCCASTANEDA
  • 4 POSTS
i replaced the clutch in my mustang about 6 months ago. recently the clutch release lever has been slipping off the pivot point. I have pulled the transmission off 3 times trying to figure out why it continues to come off the pivot point with no success. when it slide off i am able to jack the car up and release the cable and slide it back into place. It is starting to happen more often. When I replaced the clucth i also replace the pivot ball because there was wear on it. It is at the same level as it was to start.
Apr 6, 2010 at 4:10 PM
2CARPRO JACK
  • 11,533 POSTS
What kind of shape is the spring clip on the clutch fork in?There should be a forked spring to keep the clutch fork on the pivot ball
Apr 7, 2010 at 7:58 AM
PAULCCASTANEDA
  • 4 POSTS
I replaced both the fork release lever and the pivot ball. the spring clips are in good shape and not damaged they are brand new.
Apr 8, 2010 at 5:47 PM
2CARPRO JACK
  • 11,533 POSTS
Then something is incorrect if it keeps falling off.Did you match up the pivot balls before installation to be sure they were the same?
Apr 8, 2010 at 7:56 PM
PAULCCASTANEDA
  • 4 POSTS
Yep, they are exactly the same and at the same height.
Apr 8, 2010 at 8:03 PM
2CARPRO JACK
  • 11,533 POSTS
Is the cable tight against the fork? if not the automatic adjusting mechanism on top of the clutch pedal may not be holding proper tension against it
Apr 8, 2010 at 9:36 PM
PAULCCASTANEDA
  • 4 POSTS
I believe it is, but I'll double check it.
Apr 9, 2010 at 6:31 PM
2CARPRO JACK
  • 11,533 POSTS
Ok, the cable needs to hold a little bit to keep it from falling off
Apr 10, 2010 at 3:05 PM
