2002 Ford Mustang Mustang GT 2002 P0113 error IAT Sensor
2002 FORD MUSTANG
94,750 MILES • V8 • 2WD • AUTOMATIC
MUSTANGP
I have a P0113 Error code on my 2002 Mustang GT involving the air intake sensor. The car computer is revving the engine to over 2000 rpms in park and won't reduce. The computer is indicating that the incoming air is too hot, IAT, intake air temperature error, causing the engine to rev high. Worked just fine until I stressed the engine in autocrossing the car today. After one run, the engine idle stayed high and wouldn't reduce down, whether in park, idling or in drive, 2000 rpms at standstill. Hose is fine. Is this as simple as replacing a Mass Airflow Intake sensor? How can I tell if replacing the sensor is the answer? Thanks!
Jun 27, 2009 at 6:48 PM
LS WHAT
  • 23 POSTS
Open circuit in harness
Sensor signal short to power
Damaged sensor
Improper harness connection
Damaged PCM (unlikely)
make sure the connector didn't come unplugged, clean it with MAF cleaner first.
Jun 29, 2009 at 4:46 AM
