2002 Ford Mustang
2002 FORD MUSTANG
ALICIA.K
Electrical problem
2002 Ford Mustang
I can't figure out how to remove the batter. I have disconnected the neg/pos terminals, but what is holding it in?
Apr 14, 2009 at 11:07 AM
RICH CRITES
  • 75 POSTS
It is either a bracket across the top of the battery and it will have two long j bolts that holds the battery in place, Remove the nuts from the bolts lift off the bracket and you should be able to remove the battery. Be careful not the spill th acid or get any on your clothes.
Apr 14, 2009 at 1:58 PM
ALICIA.K
I wish it was the bracket, that is what I am used to! It's a box kind of thing, with a bolt on it. It is sitting in top of the lip on the bottom of the battery.
https://www.2carpros.com/forum/automotive_pictures/307703_002_1.jpg
https://www.2carpros.com/forum/automotive_pictures/307703_004_1.jpg
https://www.2carpros.com/forum/automotive_pictures/307703_005_1.jpg
Apr 14, 2009 at 2:38 PM
RICH CRITES
  • 75 POSTS
Remove the bolt in plastic block and the block will come out, then you can remove the battery.
Apr 15, 2009 at 12:15 PM
