2001 Mustang jerking, shuddering
2001 FORD MUSTANG
SEINFELDBLOCK
Hello! 01 V6 Mustang 106000 miles. After driving my mustang 4 hours yesterday (all in 90 degree weather with max a/c), after hour 3 a car that was going slow pulled to the side of the road so I could pass. I tried to pass, and my car would not "get up and go" as my mom would say. It kind of seemed like the car wanted to shift into a lower gear, but was unable to. I was easy on the car the rest of the way, but when I got to the stop light on my street, the car did not have enough power to get up the TINY incline. It seemed like the engine was getting ZERO power. When I got into my complex lot, I came to a full stop, and the entire car just kind of jerked along, but no lights. I pulled into a spot, put it into park and it stopped. Put it into drive and it started jerking a little again. Tried again 20 minutes later (car was still hot) and it ran fine. Drove it for an hour later and ran fine. Last year, I had the entire coil pack replaced, EGR valve and sensor, fuel injection replaced, and idle air control valve replaced. Also keep up with normal maitenance, etc. Any ideas on what happened?
May 14, 2007 at 4:16 PM
2CARPRO JACK
  • 11,533 POSTS
Scan the PCM to see if it stored any codes. Could be a fuel pressure/volume problem or a mixture control problem (MAF Sensor)
May 14, 2007 at 5:35 PM
