2001 Ford Mustang Oil Pan Gasket
2001 FORD MUSTANG
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
MVP5886
How much will it be to have oil pan gasket repaired by a professional? And would you recommend dyi?
Thank you in advance
Sep 21, 2009 at 5:37 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If you only have basic mechanic tools then I do not recommend you try this repair on your own. It requires loosening and raising the engine assembly in which case you must use an engine support tool. An estimate is below for having your vehicle's oil pan gasket replaced.
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_999.jpg
Sep 21, 2009 at 10:04 PM
