I have a 3 part question. First, when running the A/C (at any setting) my car tends to idle at very low RPM and stall shortly after if I don't hit the accelerator...this occurs whether cold or warm, after start-up or at a stop light...a/c problem? Second, when at a stand still, I have trouble shifting into 1st gear, and then even more going into 2nd (as if clutch isn't depressed at all), then a quick grind into 3rd occasionally...2nd gear has the most problems, shifting up or down...new clutch, fluid level, tranny, gears, syncros even? Last, is there a way to access and service the convertible top motor? Putting the top down is a breeze, going back up is almost a 2 minute chore for the motor with lots of straining noise. Please help. Much appreciated!
Apr 26, 2007 at 1:49 AM
