2000 Ford Mustang Tighting the Brake Pedal
2000 FORD MUSTANG
10,400 MILES • 6 CYL • 2WD • MANUAL
NOLES30
I have changed out the rotor and brake pads. The brakes work fine but I still have to push the brake pedal about halfway to the floor for a complete stop. Thank you
Oct 26, 2008 at 11:44 AM
IMPALASS
  • 3,112 POSTS
Hello From the information given, it appears that you still have air in the system. Air compress, fluid doesn't. Also, if they were working okay before, that is another indication of air in the system. I have attached the troubleshooting chart for you. As you see pedal travel relates to air in the system or it could be the master cylinder. I have also attached how to test the master cylinder. Hope this helps - let us know if you need more info or guidance. Master Cylinder Check Out
https://www.2carpros.com/forum/automotive_pictures/248015_Brake_Bleed1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/248015_Brake_Bleed2_1.jpg
Oct 26, 2008 at 12:08 PM
