2000 Ford Mustang emergency brake
2000 FORD MUSTANG
95,000 MILES • 6 CYL • AWD • MANUAL
CEZARJOGG
How to release the tension from the parking brake cable and disengage the cable end from the parking brake lever on the brake caliper.
Feb 4, 2010 at 12:51 PM
AUTOMD
  • 50 POSTS
try the steel threaded cable that comes from the back of your hub and is joining a short cable from the other hub--then the original cable runs to a threaded end with an adjuster nut in it--and one smaller nut on the end outside of that--(this is the equalizer bar)--you'll see it real close to your transmission.
Mar 11, 2021 at 2:28 PM
