I have a problem with the driver's front brake pads dragging, creating heavy dust and smell. This is on the driver's side only. Inspection found that one piston was stuck and the inside pad was worn at an angle. I replaced both the front calipers, rotors and pads due to the high mileage. The calipers are rebuilt units from Auto Zone.
Although there is no issue of pulling when braking, (or when releasing) the driver's pads are still dragging. Is there something in the antilock system that could cause this or could it simply be a bad hose?
Oct 21, 2009 at 12:56 PM
